Results 1 to 8 of 8
Thread: BAPP brake mount
    Feb 2008
    somerset uk
    44
    BAPP brake mount
    As the title says I am after some information on the brake bracket that came with the Bapp rough and ready forks, mine is missing along with the fender mounting hardware, if anyone has and good pictures of what it looks like that would be great, I have no idea what it should look like , then maybe I could replicate it. Any help would be appreciated Mark.
    6,728
    If you look at my full suspension 185s build I have the brake bracket , the fender brackets I never use because it put the fender low on the fork tubes and looks off , I always installed them to the underside of the lower triple clamp with a few 1/2” spacers .
    Feb 2008
    somerset uk
    44
    Thanks Mike, It looks quite a simple design, should be fairly simple to replicate. I see you didn’t use it on your build in the end, what prompted that decision? What bracket was it?
    Mark
    6,728
    I don’t remember lol , I had a bunch of kits back then and I believe the bracket I ended up with was just a cleaner design, it also holds the drum a little better I believe .
    I still have a box full of triples and brackets , I might have what your looking for .
    Feb 2008
    somerset uk
    44
    PM sent
    Feb 2008
    somerset uk
    44
    That would be awesome anything you could do to help regards mark
    Jan 2018
    Metro Detroit, Michigan USA
    78
    It does not appear that this 1984 BAPP catalog I have has the views you're after, but it has some neat information nonetheless.
    https://drive.google.com/file/d/17Dq...ew?usp=sharing
    Feb 2008
    somerset uk
    44
    Thanks Jack it still a cool read
