Thread: 250 es neutral switch???
    patriot1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2020
    Palestine, AR
    356
    Facts:
    85 250ES
    Neutral light does not come on when key is on
    Headlight does not work with key on
    Will not start with button
    Starts right up with crossing the solenoid
    Switch will kill it, so I figure it is good (?)
    Neutral light and headlight both work when running
    So, I removed and cleaned and replaced the switch wires on the right side of the engine
    Put it back on and checked connection and nothing changed-nothing changed
    Replaced the wired coming from the right side of engine with another one I had and nothing changed
    Disassembled and cleaned the switches and start button. Nothing changed
    Tips? tricks? Advice? Prayers?
    I don't know what to do next? TIA
    6,726
    Check the main fuse and it’s wires , left side next to the CDI and starter relay .
    Next thing to check is the ignition switch , it can be disassembled and cleaned, just take note of how it’s clocked before pulling it apart .
    Dec 2002
    SW Alabama
    763
    Ok the neutral switch being bad, unplugged, ect. will not cause the headlight not to work with the key on.
    Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
    Mar 2020
    Palestine, AR
    356
    Thanks guys, main fuse (hard to get to) was blown. I ordered 4 from Parszilla for 86 cents each, great deal! $9.95 to have them shipped... Not a good deal!
    I'll let you know how it comes out. Thanks again for the help.
    My other parts bikes had the originals replaces with inline bus fuses. I have read that is very common but I figured I would keep it original, this time anyway.
    Apr 2014
    Edmond, KS
    2,534
    Shipping is a killer these days. You did the right thing by ordering extras. That way you don't have to pay shipping in the future.
