Originally Posted by
Gumbo
Ah see I knew someone would correct me if I was wrong. So can be done just needs all the correct components.
The stock airbox and fittings won't allow enough air into that performance Powroll engine even with the lid removed.
Most guys just use a pod filter on the back of the carb with an air filter cover or panty hose over it. Some guys make a custom rear intake that tapers out larger so you can run a larger air filter rather than the little pod filters some guys jam on there.
