going to look at a 86 350d, I know the head, cam and cylinder swaps to a 350x. anything else I should look for? jim
81 185s
82 185s with 85 200s motor
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
projects coming along
85 200s
81 suspended 185s (can't believe I came across 2)
1982? 185s
bought it, it's a 87. no plastics, seat. head, cam, cylinder will come off tomorrow. most of the rest is headed to the scrap heap. Anything useful to trikes ( nuts bolts shifter kick start will get pulled. jim
81 185s
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
85 200s
1982? 185s
The intake grommet between the carb and head will interchange. If you don't need it I may be interested. Depends on its condition. I think the CDI might be the same as well. I maybe interested in that too. The head light lens look the same but mount up just a bit differently. My 350X Has 1 lens from a 350D and the other is 350X.
TRX450ER
ATC250SX
ATC350X
ATC110
ATC185S
XR100R
CRF230F
Raptor 125
Breeze 125
Grizzly700
The rear wheels will fit the 250 big red.
TRX450ER
ATC250SX
ATC350X
ATC110
ATC185S
XR100R
CRF230F
Raptor 125
Breeze 125
Grizzly700
headlight buckets cracked, but the lens is good. the intake boot looks cracked. I traded for a 350x a year ago that had a bad cam, I lucked out and found a complete head for 250+ dollars on ebay. I sold that 350x but have another, so I decided to start collecting spare parts in case I decide to make the 350x my keeper. And the trx350 was 250 bucks. So I think it'll be worth that in spare parts when I need it. jim
81 185s
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
85 200s
1982? 185s
any idea if the rearend is the same as a 250 sx? jim
81 185s
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
85 200s
1982? 185s
thanks. I guess I won the 350 lotto. pulled the top end off, cam and rockers are great. valves look good
cylinders good. the pistons scored so it's staying with the shortblock. jim
81 185s
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
85 200s
1982? 185s
Here is the response from my local 350D expert:
The 350D has stud bolts tapped in and the big reds and 250sx and 250 four wheelers are tapped for bolts. You can use a big red rear end on a 350D but not the 350D for any other because the stud bolts are bigger than the threaded bolts on the others
TRX450ER
ATC250SX
ATC350X
ATC110
ATC185S
XR100R
CRF230F
Raptor 125
Breeze 125
Grizzly700
thanks, I'll let him know about the differences. his family owns a machine shop so it might not be a issue to modify it.
I was just thinking. if this quad was a trike, I would have ordered a new piston, seat, plastics and tires and put it back together. I have no use for a quad, It didn't bother me at all to strip it for parts. I've brought 3 wheelers in a lot worse shape back to life. jim
81 185s
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
85 200s
1982? 185s
TRX450ER
ATC250SX
ATC350X
ATC110
ATC185S
XR100R
CRF230F
Raptor 125
Breeze 125
Grizzly700
could you ask your friend how the rearend comes off the 350? I have it unbolted and it's separated about a inch. the shaft doesn't want to separate from the pinion in the differential. I'm hoping it's just oil sucking it together. thanks. jim
81 185s
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
85 200s
1982? 185s
If you were closer I would use the bottom end. But shipping form az wouldn’t be cheap
thing is probably pretty heavy. I pretty much took any bolt or nut I can unscrew off the entire frame and motor. jim
81 185s
suspended 185s
85 atc70
1984 200s
85 350x 3rd owner
and a 72 ct70
85 200s
1982? 185s
