Thread: Correct clutch pattern
    Aug 2022
    Texas
    23
    1980 Honda ATC 110: Took apart my clutch and it was in this arrangement for the metal plates
    https://ibb.co/h8pJSP8
    But according to a Youtube video AND this schematic it appears #1 and #2 should be switched.
    https://cdn.partzilla.com/cdn-cgi/im...g-93bfee37.png
    Which one is right? Or am I viewing the schematic incorrectly?
    EDIT: #1 in reference is towards engine
    1980 Honda ATC 110
    6,811
    It doesn’t matter if it’s 1 or 2 that go in first , just don’t locate the holes where there depressing the springs . The only steel plate that pushes on the springs is the last plate .
    That middle plate would be for a clutch setup that had the short middle plate springs which doesn’t apply to your clutch .
    Hopefully I explained it correctly lol .
    Just looked at the partzilla diagram , do you have the short middle springs ?
    Aug 2022
    Texas
    23
    Yes I have two short middle springs.
    1980 Honda ATC 110
    6,811
    Then the # 2 plate was assembled correctly .
    Aug 2022
    Texas
    23
    Awesome thank you so much
    1980 Honda ATC 110
