Thread: Atc90 shifts past neutral
    Aug 2020
    Snowflake Arizona
    77
    I pick up a 77 atc90 engine in a ct90 frame has wiring issues but I noticed that when you shift down into neutral it shift past and is in gear again. Anything that can cause this.
    Apr 2014
    Edmond, KS
    2,591
    I think you're shifting backward. From what I remember, neutral should be all the way up.
    6,811
    Yep , your shifting the wrong way , all the way up is neutral .
    It’s a down shift motor .
    Aug 2020
    Snowflake Arizona
    77
    When it is in neutral it will shift up or down and be in gear again. I had a chinese 50cc atv that would shift past the final gear and be in neutral. Just wondering what could cause shifter to shift up past neutral when it should stop like my 185s.
