Results 1 to 6 of 6
Thread: Which carb for 350X?
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    300
    I am finally getting a chance to go through my 350X and correct a few things. The carb needs a rebuild but I thought about getting the 400ex carb instead. I was wondering what is the general consensus on the 400ex carb vs. rebuilding the stock 350X carb? I realize the price difference. My 350X is a rider not a collection piece. I am just trying to make it into a better rider. Thanks in advance for any advice.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    6,728
    If your factory carburetor is in good condition for sure rebuild it . The only kit I would recommend is a shindy or OEM .
    Their are a ton of threads on this site on the positives of going with a new OEM 400ex or 400x carburetor .
    Here is one
    http://www.3wheelerworld.com/showthr...0ex+carburetor
    Nov 2019
    Florida
    1,044
    A real OE Honda 400ex carb it perfect. this is also a great way to take advantage of other up grades IE: exhaust, over bore, raised compression, fancy air filter.
    mrc_builds on YouTube Channel
    My Addiction
    85 200m "Tallahassee"
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "The Money Pit"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    Manheim, PA
    5,759
    BUY a new last year 400ex carb. drill out the welch plug to access the AF screw and jet it up. $250 for a new OEM carb. Screw the used 20 year old ones. I put one on my 300x....sucker moves!
    Dec 2022
    new york
    I got an amazon 400ex carb for $40 with a throttle cable. It took some patience with a heat gun to get it together, 30 minutes of jetting and its a night and day difference, way more top end.
    Manheim, PA
    5,759
    I'd use an OEM 400ex carb which you can get a new 2014 still from honda.
