Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: 350x barn finds
    Homeless Dave's Avatar
    Homeless Dave is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2019
    South Dakota
    255
    350x barn finds
    So I bought a pair of 350xs. Saw them in the background of a listing for a 110, and was the first person to inquire so I was able to buy them. One is a 85, the other 86. The same guy bought both brand new and they have never been separated. The 85 was competitively raced until quads took over. Both lost their engines to trx250 quads in roughly 1991. The 85 has beefed up front forks and had a custom rear shock, but it is now gone. I have intentions of putting both back together, but the 85 will have its turn 1st. It is more complete. Supposedly it’s original engine is still around my local area and still running, so I might have to attempt to track it down. The 86 will probably be a 300ex powered unit.
    I think I over payed at 600$ for the pair, there isn’t much there to start with, but hey a pair of 350s with good heritage, I can’t complain! What do you guys think?
    Currently : trx400fw, ct70, 250es,200x, xl80s, 350x, 350x, Trx250X,ALT185
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    437
    Nice find. I wish I could be so lucky. Hoping to find a parts machine someday locally.
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    kiser's Avatar
    Coshocton Ohio
    525
    Glad your going to save them! It's a shame the motors were taken out but that's the way it goes. Good luck with the rebuild!
    az
    2,022
    cool score! I would have had a hard time not buying them. jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
    Nov 2019
    Florida
    1,048
    I would have bought them too. If your happy with the price that's all that matters, you could part one out and get your money back, then build the other with a 300.
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    Apr 2019
    South Dakota
    255
    Quote Originally Posted by MrConcdid View Post
    I could, but I’d rather take my time and put them
    Both together. Plus they have been together since they were new, why separate them now.
    Arkansas
    2,447
    I was going to say you overpaid because there's no, No Fear stickers on them, but the Camel Racing sticker makes up for that
    In seriousness, good find. One of the better parts is they're a bit of a clean slate. Drop that 300EX engine in without shame.
    Apr 2019
    South Dakota
    255
    Im looking for a complete 300ex. Gotta set some money aside and pick one up. I find them between 800-1000 in my area.
    Williamstown PA
    5,825
    I have 3 or so bottom ends in parts. I also have all the spacers and details needed to bolt a 300ex motor in fully. Its not a true bolt in but its rather simple.
    Apr 2019
    South Dakota
    255
    When I find a 300ex I might have to message you for some measurements on the spacers.
    Williamstown PA
    5,825
    I have a build thread on here documented how I did it. I ended up selling it off due to some reasons.
    Feb 2017
    Arkansas
    531
    If you're willing to pay.....uh.....sit down for this.......$3k.....then Powersports Surplus on fB has a 350X engine
    Good luck on the build(s). Gotta keep the trikes going
    Arky-X receives no commissions for this sale
    patriot1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2020
    Palestine, AR
    398
    Legendary find! Good job!!
    600$ for a pair is nothing, frames alone are 400$ these days, front calipers (esp the brackets) aren't too cheap either. And that's just 2 parts off of each roller...
    Unless you want the amenities of a 300EX motor, you should be able to find a 350X motor pretty easy. The bottom ends are basically bulletproof, unless the chain goes thru the stator cover. And the top ends you just need to find one with good cam journals.
    I'm gearing up to cut valve seats and resurface all air cooled Honda cylinder heads, I've even got the new addition to the shop built. I'll be all set shortly, fingers crossed!!
    Apr 2019
    South Dakota
    255
    I would like to fine a running machine in order to scavenge not only the engine but also exhaust, carb, and wiring from. I have my eyes on a trx250x that has a 350x engine in it. Sounds like it needs a cam chain, but otherwise has everything I need. My main issue with trying to source a 350 engine is mostly financial. Most engines in my area are around the 2k range, but I can buy a running 300ex for less than 1k.
