Results 16 to 30 of 35
Thread: 350x barn finds
    Apr 2019
    South Dakota
    248
    So I have started to acquire parts now! Got a front hub, axle and spacers and some decals for the 86. Also found a shock for both of them.
    I originally intended for the 86 to be done after the 85, but it’s actually a much nicer chassis and better to work with.
    And big news! found a good running 350x engine, but unfortunately gotta let my big red go. Trading a running 85 BR for a 350x engine, not what I had in mind, but I need space anyway. So not the end of the world.
    Currently : trx400fw, ct70, 250es,200x, xl80s, 350x, 350x, 225DX, trx300
    Apr 2019
    South Dakota
    248
    Figured I better show my old big red before she leaves to the new home. It’s really obvious the frame is bent, so I’m not too worried about see her go. Going back to the are it originally came from, and on top of that a close friend to the fellow I bought it from, almost like it’s meant to be!
    Apr 2019
    South Dakota
    248
    In my initial post I made mention of one of the engines having been planted into a trx250x. Talking with a friend about old Hondas yielded the location of it. He said where his 250x/350x hybrid came from and it matches. As well as a few other details. Kinda cool knowing my 86’s original engine is still going. Now if only I could get him to sell it to me!
    Apr 2019
    South Dakota
    248
    Finally have made some progress on my 86. Got the motor put in, not yet fully bolted in, but atleast for mock up. Rebuilt the brake masters and calipers, mounted the reader shock and put in new fork seals. Only needing a few more parts and I should be able to do final assembly. Only needing the header pipe (I scored a new takeoff muffler from a cut up trike from 87 ban on eBay, never been run!), airbox lid, and a throttle assembly.
    Here’s some pics of how she’s looking (don’t mind my ugly mug on the 200x (21st birthday took a day to recover from).
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    300
    The build is coming along nicely!
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Apr 2019
    South Dakota
    248
    Well today I finally got the 86 going. Needs some more refinement. Needs new exhaust gaskets where the pipe meets the head, and need a few more airbox pieces, but it runs and moves. I definitely found out the fenders s protect you 0% from mud.
    Nov 2019
    Florida
    1,044
    More than likely its just a collapsed front fork. those frames are way over built. easy fix.
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 200m "Tallahassee"
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "The Money Pit"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    Apr 2019
    South Dakota
    248
    She looks happy next to my 86 200x. Now that it’s running, I have motivation to make it cosmetically nicer.
    I also need a new front tire, the old front max is dry rotted really bad. Any good recommendations? I have the original ohstu, but it doesn’t hold air and I’d rather not ride on 40 year old tires.
    Apr 2019
    South Dakota
    248
    So I have it reliably running and dialed in to be a good rider without much issue. Although it appears to have blown out the head gasket. Nothin major, except the oil leak. So I got a top end gasket kit to re seal it. Can I pull
    the head with the engine in the frame?
    Nov 2019
    Florida
    1,044
    No, on that trike you need to pull the engine. You can pull the studs but that's a pain in the butt. you can have that engine out in 10/15 minutes.
    get some rings while you are there, freshen it up, rings are cheap.
    My Addiction
    84 200x "SouthPort"
    84 200x "Van Halen"
    84 250r "lucky"
    85 350x Code Red
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    Apr 2019
    South Dakota
    248
    Quote Originally Posted by MrConcdid View Post
    Engine is very fresh. Only has 10 hours or so since it’s last full rebuild. I’m thinking maybe a head stud isn’t perfectly tight and caused the issue.
    2,534
    I still like the Front Max tires.
    Apr 2019
    South Dakota
    248
    I pulled the engine and re sealed the top end, put in new valve guide seals, lapped valves and put it all back together. It still leaks! I used a metal gasket and torqued it to spec. Even took the valve cover back off and re checked the torque on the head bolts.
    The leak is mostly on the right side of the engine. Could it maybe be the oil feed line? I’ve never seen one of them leak before. But the oil leak is still the same spot as before, right about head gasket level.
    Jul 2019
    Shelton
    96
    Is there a crack in the oil feed line? Check it carefully. Degrease and remove all the oil from the engine and with it idling for a time see if you can see where the oil leak originates from. Were the dowel pins in place? Did someone previously deck it on a belt sander? I mention it only because I've seen it. Metal gaskets need flat smooth surfaces to seal.
  15. #30
    Apr 2019
    South Dakota
    248
    I’ll check the oil line. All dowels were in place, looked to never have been decked or anything. Someone told me maybe the head is warped slightly.
