Results 1 to 7 of 7
Thread: 200 big red issues
    Dec 2022
    Southwest WI
    200 big red issues
    I am new to this forum. I have been having some issues with a 1984 200es I bought. It started and ran good when I first picked it up. Ever since I have been having intermittent problems with it. It will start and run for 5-10 seconds and die. It doesn't do it all the time and once it runs it will run and drive great. It did die randomly on me once when driving. I have tried a few things I bought a new mukunni carb, new battery, new plug. I also adjusted the valves and the timing advance. The compression is good. It sure seems like a electrical issue. It will just die and not sputter or bog first. I'm not really sure where I should go with it from here. Any advice would be greatly appreciated
    6,809
    Try cleaning the coil wire connections and making sure the spark plug cap is secure to the wire .
    Apr 2014
    Edmond, KS
    2,591
    I think that it would be a good idea to check all of your electrical connections at this time. That includes the grounds. It may simply be a loose connection.
    Nov 2019
    Florida
    1,053
    Also, any chance you have some water or condensation in the tank?
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    419
    I would check the connection between the battery and regulator/rectifier. Some older honda TRX models have issues with that connector as they get older.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Jan 2015
    MB, Canada
    64
    Key switches are starting to go on a lot of these machines too. When it's running, try wiggling the key. Also try it with the kill switch.....
    Jul 2019
    Shelton
    96
    I would check everything mentioned above, and also if it will idle, flex/wobble/shake each harness a little bit such as the one that goes into the engine, into the keyswitch, CDI. Turn the handle bard each way. I've seen a bad wire inside a harness that would cut in and out while riding as you hit bumps. It would idle all afternoon. The insulation actually looked fine and you could not see the copper inside was broken and intermittently making contact. The clean shutoff suggests your spark is just going away. Fuel would usually be bogging, sputtering, loosing power etc. I would also suggest an ohm meter to ohm out every component that has a spec. Don't assume a new spark plug is good just because it is new. Does it get worse when engine is hot? Electrical stuff tends to go away when it gets hot and can be ok when cold before it finally fails entirely.
