Thread: How to carbs from drawing moisture
    Dec 2002
    SW Alabama
    763
    Any ideas on how to keep moisture out of carbs if the trike sits for 2-3 weeks? I use non-ethanol gas. Gas turned off. Will not start unless you drain carb. 2 different big reds. 1 usually has so much water in it that it dosen't even smell like fuel when you open the drain screw. The other will be milky looking. Once you drain and flush carbs they will start and run. Should I just leave the drains on the carbs open so water can't collect? I am in south Alabama, so terrible humidity and not uncommon to have 45-50 degree temp swings in 24 hrs.
    Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
    Jan 2014
    Prescott az
    685
    Quote Originally Posted by whiteman350x View Post
    I’d try leaving the gas turned on. Start it in a week see how it is. I leave the gas turned on all my trikes. I don’t start my big red for six months at a time fires right up. But I live in Arizona it’s not moist like there. It can be super humid during monsoon but never have water in the carb.
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    86 tri z powervalved
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    6,726
    Can run your vent lines longer , same with the bowl drain / overflow .
    Today’s fuels suck even the non ethanol sucks and goes bad quickly .
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    300
    I drain the carburetor bowl on all of my machines every time I finish riding them.
    I use ethanol free pump gas blended 50% with 100 octane AV gas.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Jul 2020
    Western Pennsylvania
    107
    Probably multiple opinions on this, but I treat all my fuel with Sta-Bil. Curious if you are using any kind of treatment.
    3 Wheels:
    1982 Honda ATC 185s
    1983 Honda ATC 250R
    1984 Yamaha 225DX
    1985 Honda 250SX
    1986 Honda Big Red 250ES
    4 Wheels:
    1986 Suzuki LT50
    1987 Honda TRX 250 Fourtrax
    2023 Honda Foreman
    Arkansas
    2,208
    The new fuels evaporate much faster than the older formulas.
    2-3 weeks? I agree with leaving the petcock on. Just keep an eye on it and make certain fuel isn't leaking past the float and the overflow drains are clear.
    Are you buying E0 fuel from a place that sells a lot? My experience has been that places near bodies of water sell the most E0 fuel because the boating public doesn't want to wreck their high dollar engines. Everywhere around me has lakes and in the summer the E0 pumps are frequented by boaters more than anyone else.
    The E0 fuel won't chemically last any longer than the E10. It's imperative to buy fresh fuel and add a stabilizer to it.
    How do you store your trikes? Outside and under a tarp is certainly going to collect moisture. Even just being outside and in something like a barn or carport isn't protecting the from moisture in southern humidity conditions. Even an enclosed shop without AC is going to collect moisture, but it won't be as bad as outside or in a carport.
    I'm a Sea Foam convert. For a large portiuon of my life I totally ignored fuel additives, thinking fuel distributors knew best. That's certainly not the case. I started using Sea Foam on a regular basis in engines that irregularity sit. I've experienced it work.
