Results 1 to 13 of 13
Thread: upgrades in 83 ATC200
    Nov 2016
    College Station, Texas
    32
    I'm planning on doing some upgrades on my 83 atc 200 and have a few questions.
    I'm looking to upgrade the carb to a 28 mm (link: http://www.nichecycle.com/ncs/mikuni...arburetor.html ) I was told it would work but I would need some sort of intake manifold adaptor. Can anyone help point me in the direction of getting this? Also would there be any other additional parts needed?
    At the same time, I will be upgrading the exhaust (link: https://www.ebay.com/itm/334578707999 )
    And lastly, the head is going to be pulled for leaking head gaskets and I saw this on aftermarket head and piston kit and am considering it.
    (link: https://www.ebay.com/itm/255723614691 )
    Any issues with this build? Am I overlooking anything? Please give me your opnions.
    Apr 2014
    Edmond, KS
    2,591
    Going by what your link says, I think that you'll be running pretty rich with that carb. Those seem like pretty large jets for a 200cc engine. It lists a 200 main and a 60 pilot. Another question is why are you wanting to use a 28mm carb? Your stock carb was a 22mm and a 200X uses a 24mm. A XR200 uses a 26mm. I'm not really trying to say that you're wrong for wanting a 28mm carb, I'm just asking out of curiosity.
    patriot1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2020
    Palestine, AR
    398
    The best and possibly the cheapest upgrade is to find a 200x roller for that engine
    Apr 2003
    Spanaway, WA
    1,244
    What's your reasoning behind going so big on the carb? Without a cam and head work you won't be likely to turn the RPM needed to make use of that much carburetor and you'll give up response and low RPM performance in the process.
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    Nov 2016
    32
    This is what I was recommended and with the upgraded head and larger piston size I thought it would be ok. Definitely open to other suggestions.
    Nov 2016
    32
    Quote Originally Posted by TrikeKid View Post
    It was recommended to me and thought it would be a good match with the upgraded head and piston size. Open to other suggestions!
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    419
    Could you let us know which 1983 ATC200 you are working on? There are 3 1983 ATC200 models. A plain 200, a 200E and a 200X. Which of these are you working on?
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Nov 2016
    32
    Quote Originally Posted by Footy View Post
    Just a plain ATC 200. No electric start and not a 2 stroke.
    Nov 2016
    32
    Any help on this would be greatly appreciated. Suggestions on a upgraded/bigger carb and opinions on the head and piston kit?
    6,809
    Can call or message four stroke tech , they sell the parts your looking for .
    https://m.facebook.com/100054606602640/
    Nov 2016
    32
    Thanks for the recommendation. Contacted them and they suggested a 30mm bolt up carb that they use. Ordered and hopefully shipping this week.
    Homeless Dave's Avatar
    Homeless Dave is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2019
    South Dakota
    255
    A few mods I’ve done with great results are:
    Xr200 cam
    Xr200 carb
    Good aftermarket exhaust
    Those will yield a good bit of difference, but still have great reliability.
    Currently : trx400fw, ct70, 250es,200x, xl80s, 350x, 350x, Trx250X,ALT185
    Scootertrash's Avatar
    In the sticks
    4,638
    Quote Originally Posted by Homeless Dave View Post
    Xr200 cam
    Xr200 carb
    I can second this suggestion. Mine runs great.....when I get the time to ride it.
