Thread: 85 200x Kick start issues after kit
    Sep 2020
    Texas
    13
    Hello all,
    I have a 1985 honda atc 200x that has the well known slipping kick starter issue.
    I was able to track down one of the kits that replaces the two starter gears & spring. After replacing all three items and getting the engine all back together it is still constantly slipping.
    It slips bad enough i have extreme trouble getting it started. The kick lever usually moves about halfway down before it seems to engage & can be lowered that far very easily. Maybe with one finger. My foot usually hits the ground when completing the kick.
    Any ideas? Thank y'all for the help
    Nov 2019
    Florida
    1,053
    Did you take any pictures of the new vs old gears? side by side maybe?
    I would be interested to see the differences, also could the spring not be seated correctly? therefore not meshing the gears firmly enough?
    I have replaced the spring only in my 84, It did not help.
    Thanks
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    Willamstown PA
    5,823
    gotta back cut gears, use a spacer, use a heavy duty washer. buying and over paying for a kit now days is over. the higher the compression motor the more you see this. Ive seen it on XR200's also.
    Aug 2020
    florida
    63
    I think your problem is the 2 outer gears that the kick lever goes to is installed wrong. They are the 2 gears under the small outer cover that the shaft comes thru. They are 2 small dimples that lines up. I think they are some videos showing had its done. I back cut my gears and installed a stronger spring and never had anymore problems until i sold it, Mine was a 84.
