Thread: 250R rear sprocket
    Apr 2009
    Port Allen, LA USA
    8
    250R rear sprocket
    Will an 85 take an 86 rear sprocket?
    Just wanna get this thing right
    Williamstown PA
    5,825
    Las Vegas, NV.
    2,527
    Quote Originally Posted by darkstar1026 View Post
    Yes, but you'll need to switch to countersunk style sprocket bolts.
    Apr 2009
    Port Allen, LA USA
    8
    Excellent. That's what I needed to know. I could only find Sunstar would make a direct replacement for the 85.
    What about the rear brake rotor? Are they the same between 85 and 86?
    Las Vegas, NV.
    2,527
    Yes, they are. For the sprocket bolts, get bolts that fit the '85 sprocket hub, but are countersunk. You can't use the '86 countersunk bolts, as they are a larger diameter. The bolt holes in the '86+ style sprockets will be much larger than the '85 bolts, but the countersunk holes will keep everything centered up correctly.
