Thread: 85 250 Big Red choke lever question.
    Scootertrash's Avatar
    In the sticks
    4,627
    I have an 85 250 BR here that the enrichener lever won't stay in the open position. If I take my thumb off of it it goes back to the closed position. Is there a way to tighten something up to stop this from happening?
    I see nothing on the switch housing that would snug things up. I haven't torn into it yet, so I'm not sure if there is something on the carb that will do the job.
    TIA
    Apr 2019
    South Dakota
    248
    Is the cable clipped into the handle bar housing correctly? How is the cable routing? Both of those have caused that issue for me.
    Currently : trx400fw, ct70, 250es,200x, xl80s, 350x, 350x, 225DX, trx300
    In the sticks
    4,627
    No clip for the cable on the handle bar housing. I'll be tearing into sometime in the next couple days. I have other plans for this machine I need to complete first. All depends, I may dig in sooner.
    I worked on this machine about 10 years ago, but I don't remember how everything went together. I DO know that it was working fine when it left here last time.
    Apr 2023
    Florida Panhandle
    10
    Is it an aftermarket cable? Is your problem that the cable defaults to the choked or unchoked position?
    In the sticks
    4,627
    Quote Originally Posted by SoFarKingSlow View Post
    To be technically correct, it's an enrichener, not a choke. To use your vernacular it defaults to the unchoked (unenrichened) position.
    Mar 2023
    Earth
    78
    Scooter a lot of Honda enricheners are adjusted at the mount for holding tension. Ive never had a 250es So I cant say for sure thats how it works.
