Results 1 to 2 of 2
Thread: 85 250es lost spark
    Homeless Dave's Avatar
    Homeless Dave is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2019
    South Dakota
    255
    85 250es lost spark
    Last time I had my 85 big red out it lost spark while riding. Didn’t sputter for anything, just died abruptly.
    I’ve tried unplugging key switch, kill switch, checked neutral safety, tried a good cdi box, new coil, plug , and plug cap. All my grounds are good any checked all wires for corrosion.
    I’m thinking my stator may have died. I have a late model 85, built 3/85. I know Honda used two different stators in 85, which style do I need?
    And will one from a trx250 work? I have one 85 and one 87 parts engines from trx250s. I know the different years had different crankshaft sizes, so I’m not sure about the flywheel fitting.
    I’m at wits end trying to figure it out.
    Currently : trx400fw, ct70, 250es,200x, xl80s, 350x, 350x, Trx250X,ALT185
    Scootertrash's Avatar
    In the sticks
    4,638
    Do you have a manual so you can test the stator? That would be my first step. Guessing at electrical problems just result in throwing out a lot of money, a lot of times for nothing.
    ETA: Here's a link to ATC Manuals:
    http://www.oscarmayer.net/atc/manuals/
    Download the manual for your machine.
    Run thru the troubleshooting chart-DONT' SKIP ANY STEPS!- You should be able to figure it out from there.
