Thread: 200x front hub/spacer question
    May 2012
    ELk Garden WV 26717
    55
    Hello, i have a 83ish 200x, when i got it, it was apart, i put it back together the best i could but something is off, i can slide the wheel back and forth on the axle im not sure if im missing something on if i have the wrong parts or what. any help would be appreciated.
Name:	200x front axle 2.jpg
ID:	270569 Click image for larger version.
Name:	200x front axle 1.jpg
    Aug 2016
    East of Worcester ma
    1,370
    Forks bent? It doesn't take much of a bend up top to multiply it at the bottom. Try loosening upper tree clamps and spin upper fork tubes, does it get better?
    shep
    Willamstown PA
    5,821
    You might have the front hub on backwards on the rim. It can move it off a good bit if not correct.
    Mar 2023
    Earth
    78
    Like shep said. Your forks are obviously bent.
    May 2012
    ELk Garden WV 26717
    55
    Thanks everyone
