How's it going guys I just recently picked up a 84 110 project and I am in the process of getting it going. The trike has spark and is getting fuel to the plug. I put a new plug in, swapped the stator out for one off a running machine, cdi box off a running machine, pulse generator off a running machine and a coil off a running machine. All the parts were swapped to the other machine and it fires no problem, the new machine does not have a kill switch but I do not believe that should be a problem. I checked timing and as far as I can tell it is correct as well as the valves. Cam is put in with the lobes facing the rest of the motor, but I'm not sure if the exhaust valve is supposed to open first once off top dead center as that is what my machine is doing. Also machine does not currently have an exhaust but for a test fire I also do not believe that should be a problem. I did not check compression but seems to have about the same amount as my other 110.
If anyone has some ideas what it could be it would be appreciated as I am lost in what it could be.
Thank you
