Thread: ATC90 cylinder compatability
    Apr 2006
    SE CA Dez in the sandbox
    894
    Are there any other cylinders that can be used to replace a stock cylinder. Perhaps from a trail 90?
    Thanks for any help.
    Have '85 350X-XR500 Hybrid,
    Had Nicholson framed: 90/110, 185s, Gen I 500, Gen II 500
    Had Bandito Framed 90
    Have Vey's Framed 90
    Have too many parts
    6,809
    Depends on what year 90 you’re looking for ?
    The early us90 motors seat differently into the heads .
    The ct90 should be the same if it’s the same era , I believe 1975-78 are the same 74 and earlier are different .
    Apr 2006
    894
    Thanks Mike, looks like it's a 1976. That opens up possibility. Looks like I might have a line on a"big bore" piston, and met with a buddy who suggested a CB750 sleeve and piston (LOL, they're probably pretty scarce).
    Trying to finish up a Joker roller I've been storing for a very long time.
    Thanks for the help.
    Rick
    Have too many parts
    May 2013
    Brownsville, Tn.
    1,271
    Rick find a CB550 cylinder. Those are the sleeves you need. You can find them on ebay for $50 to the door all day long. Standard bore is 58mm and can go out to almost 62mm.
    The sleeves will press out with little effort. You will need to machine the outside and top lip but is a simple fix with a lathe. Way cheaper than paying LA Sleeve.
    * Nicholson 500 Race Bike *
    Does the cb550 pistons have the same pin size as the 90/110 engines ?
    May 2013
    Brownsville, Tn.
    1,271
    The 90 uses a 14mm wrist pen. The 110 uses a 15mm pen. The CB550 and CB750's both have 15m pens. To use either piston you will have to modify the piston to work. The deck height is different and the skirt will have to be modified to use with a stroker.Click image for larger version.
ID:	270785Click image for larger version.
ID:	270786Click image for larger version.
