Results 1 to 9 of 9
Thread: 200x carb concern
    Nov 2011
    whitehouse tx.
    106
    200x carb concern
    Hey yall I got a oddball concern here.i picked up a 84 200x complete last week for a 100 bill.only think it's missing is the clutch cable.its in overall great shape.anyways I took carb off let it soak for about 2 days,started blowing carb cleaner threw it,got to the needle jet and it's plugged up solid.i mean solid.ive boiled it twice blew air threw and nothing.im out of ideas on this one,or does anyone out there have one laying around they would part with?thanks all
    Jan 2014
    Prescott az
    720
    Quote Originally Posted by captain2207 View Post
    Can you dig the crap out with a wire from a wire brush?
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    86 tri z powervalved
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    Nov 2011
    whitehouse tx.
    106
    Quote Originally Posted by 6spdls1z28 View Post
    I'll try the brush.i do have some old torch cleaners an I've tried one of the smallest one no help.im having a hard time going into the 90,where the needle sits and the fuel tube.my luck it's in there...
    az
    2,002
    I invested in a set of pin vice bits. ace hardware has them. jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
    Nov 2011
    whitehouse tx.
    106
    Thanks jim,I'll look into that.as I'm looking at carb,there is a "ball bearing that is pressed in from factory.what is that for?it's at the very end of the horizontal where the fuel comes in....I need that out and pressed back in lol
    Nov 2011
    whitehouse tx.
    106
    Ok I'm bout to throw the towel in on this.2 questions tho,I dought it's got rust in there but can I soak carb in clr?and 2,will a 200s,es,big red carb fit and work?I got a local guy that has parts for sale.thanks all for the input
    Apr 2014
    Edmond, KS
    2,591
    The 200X carb is a 24mm while the other 200s all use a 22mm carb. Will one from a different 200 work? It will if it bolts to the intake, but I'd change the jets over at the least.
    Jan 2014
    Prescott az
    720
    I use mercury powertune on my carbs dissolves everything and makes all the brass shine again. Regular carb cleaner doesn’t work.
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    May 2015
    San Diego, CA
    1,798
    Short answer is yes you can.
    I use the Zep brand rust remover....but I also like to heat the Berryman's can with an electric heater to help things along.
    You may need multiple soakings and boilings and air....and I mean multiple.
    Here's a link to my carb cleaning for my 84 200x.
    http://www.3wheelerworld.com/showthr...43#post1525543
