Results 1 to 4 of 4
Thread: 350X owners, a little help please?
    Scootertrash's Avatar
    In the sticks
    4,627
    I don't have access to a 350X locally, so I could use a little assistance. However, if someone is local to MPLS or the NW suburbs and would be willing to let me measure their machine....
    Looking for a couple of measurements for the front forks on the 350X. Not sure if 85 and 86 were identical, but measurements from both would help me to see any difference.
    I'm looking for the measurement from the centerline of the front axle straight down to the ground, hopefully with a decent tire mounted, not a decades old one.
    I'm also looking for the measurement from the centerline of the axle to the bottom of the taper/radius at the top of the shock.
    TIA
    MS Paint for clarity:
Name:	350X front shock dimensions.jpg
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    296
    I can check that for you. Remind me via PM this evening. At work at the moment.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    296
    From the center of the axle bolt to the floor is about 10 & 5/8 inches.
    From the center of the axle bolt up to the taper in the fork is about 9 & 1/2 inches.
    This is using a Kenda front max size 23x8x11 with 3.5 psi.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    In the sticks
    4,627
    Thank You!
