Results 1 to 8 of 8
Thread: 250r Engine Swaps?
    May 2023
    Watertown, SD
    250r Engine Swaps?
    I am new to doing these kinds of things and I am putting together a 1983 250r, are there any other engines that would bolt directly in or does it have to be a 250r motor? Any advice (about anything) would definitely help! TIA
    Apr 2023
    New Hampshire, USA
    18
    Do you have the old motor for it?
    Sent from my SM-S908U using Tapatalk
    Homeless Dave's Avatar
    Homeless Dave is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2019
    South Dakota
    255
    I see your from Watertown SD, me too! I assume your the guy my gf told me was asking questions 250r questions.
    Currently : trx400fw, ct70, 250es,200x, xl80s, 350x, 350x, Trx250X,ALT185
    Apr 2019
    South Dakota
    255
    As for bolt in engines, 1981-1984 atc250r will. The hard part about finding engine to swap is that the air coolers have the chain on the right side of the engine.
    Willamstown PA
    5,821
    flip the axle.
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    419
    There is an issue with the fitment of the shifter when switch between gen 1 & 2 engine/frame. I think one of the shift shaft is longer on one than the other.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Apr 2019
    South Dakota
    255
    Quote Originally Posted by Footy View Post
    This is true, I completely forgot about it. Been a while since I’ve been around the air cooled 250rs.
    I’ve also seen guys that have used the cr250 engines that are air cooled, but IIRC the exhaust port is not going to line up (maybe it was intake side?), as well as the kickstarter will go the wrong way for a trike.
    Sep 2009
    Suring Wisconsin
    967
    you will want to find an 81-84 R engine 81-82 same shift shaft and shifter, 83-84 same shift shaft and shifter. 81-82 red, 83-84 black. 83-84 shifters are expensive and hard to find perfect. Do you have any of the oem engine?
    Rebuilding and riding trikes everyday and lovin every minute.
    http://www.3wheelerworld.com/showthr...light=pipeline
