Results 1 to 7 of 7
Thread: '84 200x rebuild questions
    Apr 2023
    New Hampshire, USA
    18
    To start with, where do these o-rings go? There were 2 of them and I apparently missed them on disassembly. They were stuck to the inside of one of the case halves but that was after boxing up a bunch of parts to wash in the big tank at work.
    Sent from my SM-S908U using Tapatalk
    6,726
    There are only 3 o-rings that size that I can recall , 2 are under the pressed in valve guides and the other one goes between the cylinder and cylinder head on the oil galley stud .
    Part number 3
    https://www.partzilla.com/catalog/ho...00x-a/cylinder
    Apr 2023
    New Hampshire, USA
    18
    Part number 3
    Yeah I saw that when I looked at the parts fiche. You know what I think happened? Someone put two under the head. They stuck to the head when I took it apart and fell off into the case when I boxed them.
    Ok... what is the oil galley stud and does the o ring go under or on top of the head gasket?
    6,726
    The bottom right cylinder stud feeds oil to the top of the head . Place an alignment dowel and one o-ring there .
    The original head gaskets are made a little larger to accept that o-ring . Now if you’re using an OEM newer style metal head gasket I believe it doesn’t use that o-ring anymore .
    Apr 2023
    New Hampshire, USA
    18
    Awesome. Thanks for the info!
    Nov 2022
    Crompton Park Mass
    8
    That Oring might be from timing chain tensioner adjuster, or the plugs to check timing on Mag cover maybe. there are also 2 behind oil pump.
    6,726
    Good call on the two behind the oil pump , I believe those two are much smaller than the one in his picture though .
    Quote Originally Posted by bt200X View Post
