You sure your tank is venting ?
Hey guys, unfortunately my 85’ 350X with a 400ex carb has developed an issue where it will die after it’s been at WOT for more than 7-8 seconds. By looking at the plug I can tell it’s running really lean, and it has one small dead spot in the throttle if you gun it right off of idle. The dead spot has always been there, as I had to jet the idle jet up to a #45 right after I got the carb (it’s a Chinese knock off). The stock main jet has been perfectly fine, so Ive never changed it.
The bike runs great, even at wide open, so I doubt jetting is my problem. Like I said, it only dies after 8 seconds or so of being at wide open. Anybody else have this issue? I’ve already tried increasing fuel flow from the tank, and cleaning the screen in the inlet of the carb as I’m suspecting that I’m running out of fuel in the bowl. If anyone’s had this issue or has any advice, leave a reply! Thanks!
YOU NEED MORE FUEL. You can not put a carb on a different model machine and think it will run correctly. I put a 2014 OEM brand new 400ex carb on a healthly mild built 300ex...i ended up needing 45 pilot and 178 main....that's crazy huge compared to a stock 400ex. (38 pilot / 138 or 142 main stock) You should be around the same area depending what exhaust and air filter. Chinese carb stuff is not designed like OEM stuff. The sizes of jets are not even close. I only buy jets from www.jetsrus.com
If you are running corn93 = ethanol gas, it will burn hotter than normal non ethanol gas. The hotter burn does not help to jet, it can leave the white electrote barely tan on a properly jetted.
Buy a range of jets, start fat and work your way back. You are just sucking fuel faster then carb can keep up. Also if you have a metal tank with rust in it and old petcock i'd replace with plastic tank and new petcock. I just fixes a scramber 500 which needed 10 mins to warm up on choke in summer time...its fuel filter and petcock were clogged so bad it was just starving for fuel.
Alot of carb issues are not carb issues at all. They are intake, or maintenance issues.
Remove your fuel line and let it drain into a bucket for a minute to see if flow decreases with time. If it does, remove the fuel cap and see if that improves it. If it does you likely have a blocked vent. If it doesn’t help then you likely have a plugged petcock or in-line filter.
If fuel flows freely and consistently for a minute I would remove the carb and look for junk in the float bowl. You may have a large piece of something that remains on the bottom at low rpm but is getting sucked up against the opening of the main jet at WOT and then falling back to the bottom of the bowl once the engine stops.
If it’s not that, check your float height and if it’s good you can try a larger main jet, but I doubt that’s your issue if you can get 8 seconds of strong running time out of it before power drops off.
You can try opening up you fuel screw a 1/4 turn at a time to get rid of you flat spot, but if you get to three turns out and it’s still there you may need a larger pilot, or to raise your needle.
It sucks to get old
I have seen aftermarket petcocks that are half the size (output) as the OE petcock, I run a Honda 400EX carb on all my 350x's.
The smaller petcock may also have a small fuel line.
MrC.
mrc_builds on YouTube Channel
My Addiction
85 200m "Tallahassee"
84 200x "SouthPort"
84 200x "Van Halen"
84 250r "lucky"
85 250sx "Enterprise"
85 350x "The Money Pit"
85 350x Code Red
86 250r "Unicorn"
86 trx250r
88 Lt250r Suzuki
So let me explain some of the troubleshooting I’ve done. I have indeed checked to see if my fuel cap is venting, and it is, and flow from the tank is a steady strong stream (even after 1 minute +). I do agree with it needing bigger jetting, as it does appear to be running lean. I’m just unsure at this moment what else could be wrong.
The float doesn’t have any holes or faults that I notice, however the float needle looks as though it’s seen better days. When I pulled it out it had a white ring right where it contacts the seat, something that I haven’t really seen before. What I’m wondering is if my needle is sticking to the seat. My grandfather has said that he’s had to polish needle seats in the past to keep them from causing the needle to stick, but I believe that was with a brass needle as well as a brass seat. My needle is rubber, theoretically removing the idea that the seat needs to be polished. Nevertheless I’m going to attempt to investigate that today if I have the time to.
I’ve heard of people having issues having to do with air filters and air boxes, but it has the stock airbox and the same filter from when it used to run good. And the filter is indeed clean.
Right now I’m going to keep investigating, and if I don’t find anything I’ll tear my carb down all the way again and see if maybe there’s a clogged port somewhere that I’m missing.
You may have answered your own question. Usually the needle and seat stick when the vehicle has been parked for a while, but there is a possibility that it isn’t fully opening, and therefore restricting the flow of fuel. I’ve also polished them in the past to clean them, toothpaste works great, but once they start leaking due to wear you need to change them. Do yourself a favor and replace it before you bother doing any more trouble shooting.
It sucks to get old
Clean it all up, dont be scared to just jet it pretty fat while you are in there. Run a new fuel line around the carb in a spiral so you can get the tank off and on easy.
I might as well add my 2-cents... It's a Chinese carb just buy another $40 dollar new one not knowing that any replacement parts u buy may not fit it anyway. You're lucky to have gotten 2-3 yrs out of it.
shep
There are two sizes of 400ex carbs 35mm and 38mm was used on the later models with the A/F screw plugged with a welch plug for no adjustment due to emissions. If its chineese carb good freaking luck. Knew a guy with one on a 350x had nothing but issues. Went to OEM 400ex jetted correctly ran perfect.
I am looking into simply replacing the carb completely with a real kehein carb, I’m just not sure if I wanna bite the bullet yet. Price tag is a little steep to me .
