Originally Posted by
Fixer_Upper
So let me explain some of the troubleshooting I’ve done. I have indeed checked to see if my fuel cap is venting, and it is, and flow from the tank is a steady strong stream (even after 1 minute +). I do agree with it needing bigger jetting, as it does appear to be running lean. I’m just unsure at this moment what else could be wrong.
The float doesn’t have any holes or faults that I notice, however the float needle looks as though it’s seen better days. When I pulled it out it had a white ring right where it contacts the seat, something that I haven’t really seen before. What I’m wondering is if my needle is sticking to the seat. My grandfather has said that he’s had to polish needle seats in the past to keep them from causing the needle to stick, but I believe that was with a brass needle as well as a brass seat. My needle is rubber, theoretically removing the idea that the seat needs to be polished. Nevertheless I’m going to attempt to investigate that today if I have the time to.
I’ve heard of people having issues having to do with air filters and air boxes, but it has the stock airbox and the same filter from when it used to run good. And the filter is indeed clean.
Right now I’m going to keep investigating, and if I don’t find anything I’ll tear my carb down all the way again and see if maybe there’s a clogged port somewhere that I’m missing.
