Results 1 to 3 of 3
Thread: 1984 200x, which side is easier...
    Apr 2023
    New Hampshire, USA
    18
    Have my bottom end ready to reassemble. Which side do you normally drop the trans, crank, etc. into before putting the halves together?
    Sent from my SM-S908U using Tapatalk
    6,809
    I always put the parts in the left Case half , mainly because of the inner kick starter assembly / gears .
    Not sure if it’s even doable any other way .
    Apr 2023
    New Hampshire, USA
    18
    That's where I ended up going with it. I don't have a book but was planning on putting the kick assembly in the right case half and everything else in the left.
