My z doesn’t have the mark on the case and neither does my yz case. Can someone put a up close picture of theirs. The manual picture you can’t see it either.
The one without the stator is the yz.
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
86 tri z powervalved
85 BIG red
18 rmz250
87 lt80
19 ttr110
Anyone? Would help out.
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
Seriously guys where is the mark on the case supposed to be?
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
Sorry buddy, I’m nowhere near mine, but I recall having a similar issue. Any chance the mark is on the rotor and you line it up after installing it using the slotted holes? That’s sounds familiar to me.
Worst case, set it in the middle of the slots and see how it runs. I’m sure you’ll be within 2 to 4 degrees of optimal.
It sucks to get old
You can’t line the flywheel marks on the stator plate. It’s so many degrees before top dead center. The manual I have for the yz wants you to make a new mark on the cases. But you need a degree wheel which i don’t have. I have a dial indicator to get tdc. I just wanted the stock line so I could advance the timing a hair. I don’t know why I’m so worried about it runs fine seems like wherever I put the stator plate.
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
Starting to remember thus now. I think it’s like 4 degrees BTDC or something. It’s been a long time.
It sucks to get old
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
If I'm understanding the Tri-Z manual correctly, the only timing marks are on the rotor & the timing plate. It doesn't show any scribed timing marks on the engine case.
The manual shows holes in the rotor to access the timing adjustment screws. Maybe you have the wrong rotor installed?
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
We’ll never mind again. By the tri z manual these do not line up at all. I have a dial indicator on it at tdc these lines do not match up at all. I could adjust the plate all the way and it still wouldn’t line up.
You will have to zoom in on the picture to see the lines on the rotor and the plate. I have a yz top end on it I don’t see how it can be that far off.
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
Just give up and give it too me
shep
wait no, then i'd be stuck just like u are.
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
I adjusted the plate all the way as close to the rotor lines as possible. Thing runs hard has a slight little break up on top end though. Don’t know if it’s jetting or what.
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
