ATC 70 no spark
Hello, so I got a atc70 that had no wiring harness and no off switch. I added a switch, and “T’d” a wire from switch to the black wire coming out of the flywheel, to the coil. Still no spark. I checked the points, in the “F” position I’m about .014”. Wondering what else could be wrong unless I’m doing something wrong. I also put a multi meter to the black wire and have 2.1vAC when I pull the pull start.
Check wiring , hook up only what is needed and try it. What's the "T" for ?
//ArrowChat Integreation Code
