I've swapped an engine from a derelict 84-85 (cant remember the year) atc125m into a 1968 honda ct90 frame as a "resto-mod" project.
The motor I got had the exhaust port damaged so I bought a new head off marketplace a swapped it on.
I've got it back together but it won't run. I suspect I've gotten the cam timing off somehow.
-Motor set to "T" mark on flywheel in the little window.
-Cam is set in so once bolted in, the timing advance lines up with the line on the CDI pickup ring.
-Valve clearance set.
-I have spark, fuel, and compression, but it won't fire, even with a puff of ether.
Please someone help before I toss it all in the corner. Thanks.
