Results 1 to 3 of 3
Thread: Help
    May 2023
    Anchorage alaska
    8
    Help
    So my 85 bigred will only start if I bump start it, It doesn’t have electric start and the kick start doesn’t work and when k do start it it idles to high and the idle screw isn’t touching. I have a small leak coming from my oil filter case, I have a broken bolt in there and I jb welded it but it still slightly leaks I wonder if it’s from that. I really don’t know why the kickstart doesn’t work but I have a new clutch case coming, so when I put that on I’m gunna replace the one way bearing and the clutch plates see if that helps but lmk what y’all think
    Homeless Dave's Avatar
    Homeless Dave is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2019
    South Dakota
    255
    Kicker not grabbing is the one way bearing. As for high idle, it’s lean. Make sure you don’t have vacuum leaks. With the engine running, spray around the intake side with some carb cleaner. If it revs higher, it’s a leak.
    Currently : trx400fw, ct70, 250es,200x, xl80s, 350x, 350x, Trx250X,ALT185
    Nov 2019
    Florida
    1,048
    Id add clean the carb too.
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "The Money Pit"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
