Results 1 to 15 of 24
Thread: How to put a 350x suspension on your 200x
    NE. Ohio
    484
    Alot of people have been asking me whats involved in the 350x suspension swap. so I decided to post the details. If you are thinking of doing this conversion, you could save yourself alot of work if you bought this.Shock mount on Ebay
    Its the last one I have.
    First thing you need to do is gather all the parts needed to do the swap.
    Parts needed for the front...
    1. forks
    2. triple tree
    3. front break caliper, break line and pads
    4. front fender
    5. headlight
    6. 350x front rim, hub and axle (optional)
    Parts needed for the back...
    1. Rear shock
    2. Modifided shock mount
    Front-end
    The front end swap is very easy. After you remove the 200x front-end, cut off the steering stop tray on the front head tube. Now you can install the 350x front-end. A new steering stop will need to be welded in place so that the new forks don't hit the gas tank. (See pic)
    Also you will notice that the bearing posts on the two tripple trees are set at different angles. the 350x tripple tree will set your forks parrellel to the head tube. The 200x forks don't run parrellel to the head tube they are set so the forks are kicked out. This is why when you add a 350x front-end you dont get a "chopper" look. The front suspension swap will add about 2" in lenth and about 2" to the height.
    If you plan on re-using you 200x front rim hub and axle, you will need to cut the bushing that centers your wheel. the 200x bushing is too long and will make your wheel off center. Just cut some off and your good to go. Its not a big job, and can be done when you are ready to attach the front wheel. that way you can see exactly how much needs to be removed.
    Rear-end
    The rear shock swap is more dificult, only because it involves making a new mount.
    One way is to convert the 350x shock mount. To do this you will have to narrow the mount so that it is the same size as the 200x mount width wise (so that it fits where it bolts on the swing-arm) The 350x mount is wider. After the mount has been narrowed it will need to be cut and a extention piece welded in place. (See pic... side by side with stock 200x mount)
    I would say that about 4" is gained at the fenders. and since the 350x shock is beefier it will allow you to jump higher without bottoming out. Also riding double will no longer kill your fenders.
    I recomend that if you do the 350x suspension swap, that you also add an extended swingarm and an extended axle.
    It just makes sence that since you have added height to you trike that you should also add to the width (for stability porposes)
    Here are a few more pics so you can compare and see how much is gained. The animated pic is without the rear shock.
    Oswego, IL
    1,858
    u want a pic of my frame up here i jsut cut off the stop and im getting ready to weld some stainless steel on for a stop? let me no if u want that for a reference
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    so the 200x brake line and cailper will not work with the 350x front end?
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Oswego, IL
    1,858
    no your front wheel and axle will tho. u can use the 200x master cylinder u just need a 350 caliper and line.
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Jun 2003
    englishtown NJ
    2,676
    would this be the same process to do on a 86 200x?
    NE. Ohio
    484
    Quote Originally Posted by vartiak15
    Hell yea, put it up there! This is the thread that I'm going to refer anyone who asks "how to". You were asking not long ago , and probably would have loved a thread like this. I would suggest that you use a mild steel or chromalloy rather than stainless steel though, stainless dosent fuse well with anything other than stainless steel. So your stop might drop
    Quote Originally Posted by deathman53
    Not sure about the 86-87, but, that question has been asked before, and I think it didn't get answered? I know a guy who has an 86 and I will make a point to check it out the next time I see him.
    how many inchs was the swingarm extended?
    85 Honda 200X
    88 Honda CR 125
    NE. Ohio
    484
    It's extended 4"
    Jul 2004
    Sunderland, MA
    7
    Sorry, off-topic question coming: What kind of tires are those on the back? They look similar to Spider Trac's. 2-ply? 4-ply?
    NE. Ohio
    484
    Quote Originally Posted by DevinM88
    http://www.maxxis.com/atv/productDet...ID=1&BrandID=3
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    muddy do you have a better pic of what your new steering stop looks like? i can't really see it in that pic
    Caution
    Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
    May 2004
    New Zealand
    129
    Muddy....Thanks for this tech article. Very helpful. The link to the shock mount on eBay no longer works (old I guess). Can you advise what you were recommending here for the shock swap?
    I'm very keen to do this mod and if I can avoid cutting and welding a dogbone, I'm all for that! Any help appreciated.
    NE. Ohio
    484
    The link to the Ebay auction was for a newly fabricated mount.
    I wanted to make a completely new linkage for my 200x, so while I was at it I made a few extras. I put one on Ebay and sold some on the boards. It's easy to make one if you have the right equipment. Or, You could talk to a machinist and have one made in billet aluminum.
    I'd post a couple of pics of the ones that I made but I can't find any at the moment. If you need and help figuring thing out let me know. Meanwhile I'll look for those pics.
    May 2004
    New Zealand
    129
    Cool, that would be great, thanks. I guess I could fabricate one too. If you cut and welded the 350X one, what sort of weld did you use? Tig, Mig? Also, am I right in thinking the top 350X mount will slot straight into the 200X frame mount?
    Thanks.
    May 2004
    New Zealand
    129
    Muddy, Would you have the dimensions for the hole spaces (center to center) for all 3 on your modified dogbone?
    I'm going to fabricate a linkage from scratch and this would be a big help.
    Thanks
    EZ
