Thread: How do you adjust the cam chain on an atc 70?
    Nov 2002
    Kirkville, NY
    3,831
    Like the title says, How do you adjust the cam chain on an atc 70? I can hear mine is loose and I don't want to do any harm.
    Thank!
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Aug 2004
    Ab Canada
    4,368
    the auto adjust is under or near the pull starter, just start it up loosen the i think its a 14mm nut, give the little slot screw in the middle a turn out and then tighten the nut back up, thats what my manuel says, and then theres a bolt under the motor, looks like an oil drain bolt, it comes undon and there is a little screw type tensinor, to tighten the chain you turn it in, to loosen you turn it out....hope this helps
    1985 Tri-Z-
    Austin, Massachusetts
    1,591
    anyone have the right answer here? the page is missing from my manual.
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
    May 2009
    S.E. Michigan
    1,250
    The 70 has a non-adjustable (not user adjustable) tensioner. There is a spring and a pushrod that install through the bottom of the motor. They push on a linkage arm behind the stator plate which has a tensioner sprocket which puts the right tension on the cam chain.
Name:	Cam Tesnsioner 1.jpg
Name:	Cam Tesnsioner 2.jpg
Name:	Cam Tesnsioner 3.jpg
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    250rfan's Avatar
    250rfan is offline Sickest custom 450R ever. Arm chair racerJust too addicted
    SCOTLAND - UK
    479
    Guys
    Does anyone have first hand experience with working on the ATC 70 engine.
    In particular the cam chain tensioner?
    I have removed the 14mm seal bolt from beside the drain plug and I have backed out a slotted bolt when the bolt came out so did a spring and a rod.
    I have put it all back in but I do not know how much to tighten the slotted adjuster bolt prior to installing the seal bolt again?
    Am sure there's some guru's on here know what am talking about here's a picture of the set upClick image for larger version.
    1986 ATC 70
    1985 ATC 250R - Hondaline Special
    1985 ATC 250R - Flat Track 'Privateer'
    1985 ATC 250R - HRC 450RR.
    1986 ATC 250R - HRC Flat Track.
    1998 Honda Laegers TRX 250R (CT 350 PV) N/F cr500 link.
    1998 Honda Laegers TRX 250R (Sparks 330) N/F cr500 link.
    1999 Honda Laegers TRX 250R (Sparks 330) N/F cr500 link.
    2016 Yamaha Laeger's Banshee YFZ 350 (DRI 350) N/F cr500 link.
