Results 1 to 15 of 51
Thread: How to power valve your Tri-Z
    Mar 2004
    North Central Ohio!!
    2,712
    Well, I thought i'll go ahead and start this thread for anyone that's curious.
    I've started my engine assembly and i've been documenting it.
    In case anyone wonders why you would do this, it has been said that this drastically improves overall performance of your engine, giving it more torque thru-out the powerband.
    First your going to need to locate a complete 83-87 YZ250 engine. You can either use the whole YZ engine or just the components related to the power valve, which is what I did. It works the same either way.
    The first part neccessary to swap is the crank gear, if you choose to use the Tri-Z lower engine. The gear off the YZ is a double gear used to operate the power valve governer.
    Next you need to install a bearing in the Tri-Z case for the governer. These are still available from Yamaha for $11.00
    Attached Thumbnails Attached Thumbnails Powervalve 1.jpg   Powervalve 2.jpg   PowerValve 3.jpg
    Mar 2004
    2,712
    Here's a couple shots of the YZ and Tri-Z cylinders beside each other. Notice the volume difference in the intake.
    The intake is also angled slightly to the left, which is an issue we will deal with later.
    Attached Thumbnails Attached Thumbnails Powervalve 4.jpg   Powervalve 5.jpg   Powervalve 6.jpg
    Mar 2004
    2,712
    Now we'll address the modifications neccessary to adapt the Tri-Z clutch cover for the power valve governer.
    First a bearing needs to be installed in the clutch cover to support the governer. These are still available from Yamaha for $11.
    Then you must knock out a punch plug from the Tri-Z cover. All of the casting and machining to accept the power valve equipment is done from the factory. You need to simply install it.
    Once the plug is out you'll need a seal to replace it. This is still available from Yamaha for $6.00. Then just install the rod assembly and governer from the YZ engine and cover into the Tri-Z cover.
    Attached Thumbnails Attached Thumbnails Powervalve 7.jpg   Powervalve 9.jpg   Powervalve 8.jpg
    Watertown, New York 13601
    3,382
    This thread has been done before. Can't wait too see the finished product!!! Wish i had one.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Mar 2004
    2,712
    That's where i'm at so far. I'll install the cylinder and finish it up later this week. Still waiting on the piston. I'll also cover how the install goes into the bike.
    Mar 2003
    Kansas
    1,507
    Very informative Derrick! Great thread!
    Jan 2005
    Columbus, Georgia-Mid Dixie
    5,301
    I do not suppose you have a printable form of instruction sheet.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    83 YTM 200L For sale,
    82 Tri-Zinger 60 For sale,
    8? YTZ 80 Conversion,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Las Vegas, NV.
    2,529
    Looks much easier to adapt the YZ cylinder & governor to the Tri-Z, than it was to adapt the CR cylinder & governor to my ATC 250R. Now every Tri-Z's gonna be powervalved! Cool thread Derrick!
    Jan 2005
    5,301
    Which way does the stock YZ kicker go? Front or rear?
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Mar 2004
    2,712
    Kicks rear. When I do my other YZ engine, I'm going to do it the opposite way and use the YZ bottom end. So, i'll be switching the kicker gears. It will be a couple weeks before I get to that though. I'll add all that info to this thread as well.
    Jan 2005
    5,301
    So it is not neccassary to use the whole Tri Z side cover on a YZ bottom end?
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Front royal, va
    2,186
    the easiest thing to do ,like i did, was swap the whole top/ bottom in place, my intake is straight in, yours it at an angle..mmmm....great information for the ones with questions with this swap, next i think im going for the 426 or 450 thumper in one , problem is those engines cost way too much
    Mar 2003
    Kansas
    1,507
    What year motor you got Derrick? Mine is an 87 and its slanted to. I know 88 on up went back to 6 pedal reeds, and had a straight intake.
    Mar 2004
    2,712
    Both of mine are 87's.
    May 2002
    Texas
    2,670
    Good stuff Derrick! Now hurry and finish it!
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
