Hey. Heres a current picture of the 500R. I just got the seat today. As you can see its far from fitting correctly. I'm going to remold the seat pan and then recover it but I'm waiting on my 400ex subframe to arrive before I can get to fabing it all up. I'm going to make a custom cover too.
I'm concerned about the fender hieght an such. Obviously it won't be the same but someone with a 250R could you measure how much distance is between the reqar wheels and the rear fenders height wise. Obviously mine won't be the same but it will help me in setting the subframe at the right height. Any info/opinions would help cause I'm building this thing from pictures and such so i don't know the best alignment and etc. I do know I need to take in to acount the fact that the suspension isn't loaded so the fender will sit at a higher angle untill the suspension is loaded. Right now the seat height is so rediculously high. I know once its all fabbed up correclt the fedner/seat height HAS to be much lower or it will be unridable/unslideable. Any info is welcome. Thanks in advance for your thoughts and opinions.
