Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: 1981 250r and a 1984 250r
    Kansas
    62
    Quote Originally Posted by Guccimonty805 View Post
    Did you have to use a diffrent shifter because on my 82 engine the shifter is diffrent
    Yes, you have to use an 83-84 R shifter to match the frame, AND you have to replace the shifter shaft (81-82 R shaft is longer and won't fit in the frame)... OR you have to do what I did and cut down the 81-82 R shifter shaft. I cut mine with a cutoff wheel because I didn't have any use for the first gen shaft because I don't have a frame from those years... Either way you go you still need a different shifter... I wouldn't recommend cutting the shaft like I did, but they are hard to find and weren't cheap when found from what I remember.
    (See the few posts directly above yours for explanation and pictures.)
    Hope this helps!
    1983 Honda 250R
    1985 Honda 350X
    Kansas
    62
    To add to my previous post... if you notice in my third picture (sorry it's kind of close up) the 83-84 R shifter has a riser on it that takes it up and over the frame. The 81-82 shifter does not have that riser to my recollection. This is why you have to change the shifter as well.
    1983 Honda 250R
    1985 Honda 350X
    Jan 2023
    Santa maria California
    7
    Or did you make a custom one
    Jan 2023
    7
    Ok cool thanks
    Jan 2023
    7
    Nvm I just now noticed mesaagaes
    Jan 2023
    7
    Thank you I'm gonna cut it then buy an 83-84 shifter
    Jan 2023
    7
    How much did you cut off bro?
