Results 1 to 15 of 22
Thread: 1981 250r and a 1984 250r
    Jul 2004
    minnesota
    689
    will a 1981 250r engine bolt in the frame of a 1984 250r and if so, do i have to use the 81 wiring harness with it or does that interchange also??
    my trikes:
    1983 honda atc 200x-k&n filter
    2002 yamaha raptor 660r, yoshimura slip on, prm grab bars
    1978 chevy nova, 454 v8, bds blower, 150hp shot of nitrous, full roll cage, a real power house.
    1991 chevy s10 4x4 350v8.
    1986 250sx
    YES its fast NO you cant ride it.
    Jan 2005
    Springfield
    328
    81-84 are same engines
    Jul 2004
    minnesota
    689
    ok i did not know this, thanks for answering my question.
    my trikes:
    1986 250sx
    faf_racing's Avatar
    faf_racing is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2005
    pensacola florida
    187
    get the motor bolted in then the wiring?? use what most accomadates it like headlites taillites etc....
    The shifter shafts are different, the 81-82 will hit the frame on a 83-84
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Jun 2003
    South of Rochester, NY
    3,470
    Quote Originally Posted by raptor
    Not exactly.... the shifter shift is longer on the 81-82 motors. It will NOT fit into the 83-84 frame w/o changing the shaft. The connections for and the CDI's themselves are different in the wiring harness.
    Bruce
    PS - Posted at the same time there Blazer... didn't mean to repeat the info!
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Jan 2005
    Springfield
    328
    im sorry for my in-correct question. thanks for backing me up. i did not no this difference!
    Jul 2004
    minnesota
    689
    ok so what exactly will the shift shaft hit, can that part be bent at all to clear because i realy want to change frames becuase the 84 has way better suspention and brakes and the styling is way nicer.
    my trikes:
    1986 250sx
    Jun 2003
    3,470
    It will hit the frame of the 83-84 frame, so you will need a shifter shaft out of a 83-84 motor. You can't really modify the frame to avoid this.
    Bruce
    Jul 2004
    minnesota
    689
    like does it hit by like a half inch or so or more??? and does anyone have a pic of the part of the frame that it hits.
    my trikes:
    1986 250sx
    Kansas
    62
    Zombie thread brought back... ��
    Okay, so after attempting this same swap I ran into this same issue. Has anyone ever tried cutting the shaft shorter and making their own splines or use a pin to hold the shifter in place on the shaft? I have yet to find a 83-84 shaft for sale (second gen parts seem pretty hard to come by), and I would prefer not to tear the bottom end apart and pull the clutches. I'm considering cutting the shaft but would appreciate some other thoughts before I do this.
    1983 Honda 250R
    1985 Honda 350X
    HondaRidr's Avatar
    Salt Lake
    341
    There is an aircooled 250r page on Facebook that might be helpful in finding the shifter shaft.
    Kansas
    62
    Sadly I don't have Facebook anymore. I decided because I don't have any use for the longer shaft since I don't have a first gen R I would try some redneck ingenuity. I hacked it off and put a pin in it... It seems to be holding fairly well! It also clears the second gen frame with ease now. I'll try and add some pictures of the hack job.
    1983 Honda 250R
    1985 Honda 350X
    Kansas
    62
ID:	269530Click image for larger version.
ID:	269531Click image for larger version.
    1983 Honda 250R
    1985 Honda 350X
    Jan 2023
    Santa maria California
    7
    I have a question
    Did you have to use a diffrent shifter because on my 82 engine the shifter is diffrent
