Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: 85-86 250r knocking sound
    Nov 2004
    Waterloo IL
    2,701
    Quote Originally Posted by slothminx
    its definitly isnt the engine knocking at idle, engines only knock like that when under load on the wrong octane but if it is that the engine is knocking you can change the ignition timing to compensate but i cant remember if you retard it or advance it
    will
    Retarding the timing will reduce spark knock but you will also lose power.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Jun 2004
    potsdam ny
    1,227
    yeah, i tried that, i have best results +2 degrees..... but i talked to psi today, and they said that most likely its piston slap, i think im gonna pull my top end and check the piston-cyl wall clearance, the wiseco box said that the clearance was 3 thousandths (.003), so hopefully thats what it is and i will make sure the place i had it done at buys me a new piston and does the next bore job for free....bastards
    Jul 2004
    spokane wa.
    19
    my 86 r has a clunk, clunk, clunk sound while at idle or low rev. it definately makes you think something is wierdo. this same bike also runs out great and hauls arse while riding it. i'd say your knock sound is normal in your bike. for comparison sake, i have a suzi quadracer 250r that has a much different sound at idle than the honda r. it is more like a small engine rev- like a chainsaw, weed eater, etc. no knock, just whiney- so to speak.
    Jun 2004
    potsdam ny
    1,227
    thats exactly what mine is doing... it sounds like there is a serious problem with a main bearing or something...i will be splitting the cases tomorrow night to find out whats up...hopefully nothing, but its best to make sure cause god knows engine parts are big$$$$ compared to a gasket set and a couple hours.....thanks man
    Feb 2005
    washington
    58
    i have been told it the ports in the head are round and big gives pist slap and new ones have a running in the middle so it not there? so how do * balance the motor if you habe to light of pistion in it with counterbalance. i have car knowlage on balancing so do hipo bike shop spin balance these motors?
    Jun 2004
    Oregon
    1,782
    Quote Originally Posted by hrc85250r
    Dude your looking to much into this..5 or more people have said their Rs do the same thing at low rpm...So why go though all the trouble lol..Like they always say if its not broke dont fix it.. Maybe your ping is alot worse than what im thinking...You need to film it ..
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    Jun 2004
    potsdam ny
    1,227
    i am going through all the trouble cause i dont have a lot of money to fix it if it throws something through the cases or something grenades inside the tranny.....and i wont know if its broke unless i split the cases, and it isnt a ping, its a knock.....and i would tape it but i dont know anyone with a digital camcorder....
    Mar 2005
    Kansas
    26
    All 2 strokes do it at idle. I have a nice NICE 86 250r and you can hear it. It's normal. If you don't like the knocking then get a 4 stroke!
    Jun 2004
    Oregon
    1,782
    Quote Originally Posted by Ryan DeBerry
    My buddy has a 03 CRF450 and it knocks too LMFAO!
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    Feb 2003
    southwestern NY
    641
    every 250r has a knock to it.I was told by the best honda tech that I know that it is a slight piston slap,and it won't ever go away.you can replace every part in the motor and it will still be there.you won't have a problem with it,just run it.
