Results 46 to 60 of 62
Thread: Blaster engine in a Tri-Z..??
  1. #46
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by TRI Z Racer
    why woulldnt you just sleeve down? sounds like destroking a crank would be harder to do, this way you keep the same stroke and crank, all thats changing is bore diameter and piston diameter. Seems easier to me, but i dont really know how that kinda stuff is done
    it would be eaiser to run a shorter stroke and a longer rod(which wears out way slower that the piston) than resleaving it and havin to use a 1 off piston or somethinhg like that when you could still use all the other stock syle rings n pistons which wear out faster then the rod......thus saving money in the long run..
    1985 Tri-Z-
  2. #47
    TRI Z Racer's Avatar
    TRI Z Racer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2002
    Boscawen, NH
    342
    ahh, i see the light. makes sense, the angle on the rod is less so the piston has less side to side forc e on it. would be better to destroke then.
    1985 Yamaha Tri Z 260PV
    Suzuki Trail Buddy 50
  3. #48
    Blasters are 6 speeds,as far as the vitos kit is a waste the porting is just like stock on the vitos set up and the gains are minimal.places like cp customs can just port your top end and get * in a tri z hp range easily throw some good porting on a 240 big bore from the same place and ud have a monster.
    theres quite a few places that offer nasty set ups for the blaster.
    1983 Honda 110
    1967 Mustang
  4. #49
    May 2002
    Southeastern Wisconsin
    3,658
    Hey Derrick, I found this blaster site full of info. It's full of a bunch of kids bitching at each other too but the info is there.
    http://pbforums.mxadrenaline.com/index.php
  5. #50
    Id say Blasterhq.com is the best for blaster info :X
    1983 Honda 110
    1967 Mustang
  6. #51
    Nov 2004
    Waterloo IL
    2,701
    My opinion.
    Just race with a Blaster or chop the front end off and weld a 3-wheeler front end on it before you "ruin" an TRI-Z.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
  7. #52
    May 2002
    3,658
    Quote Originally Posted by Blown 331
    My opinion.
    You won't be able to make a race worthy trike by "chopping" the front of a blaster and installing forks. Never has and never will happen.
    How is he going to ruin a Tri-Z by installing a different motor? Worst case would be different motor mounts. It's not like he'd be "chopping" the thing up.
  8. #53
    Nov 2004
    Waterloo IL
    2,701
    Ok, you got me with both of those. I know converting a Blaster to a 3-wheeler isn't a feasable thing to do. And just bolting a different engine in a TRI-Z doesn't sound bad, but Id still just race the Blaster or use a 350X. I think you'll be quicker with a Blaster on a track than a Blaster powered TRI-Z. The Blaster kicks backward too so you have to watch the fender
    A Blaster engine in a TRI-Z just doesn't sound appealing to me, don't know why. But I guess if that's your thing then go for it.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
  9. #54
    May 2003
    Houston, Texas
    2,409
    Quote Originally Posted by Jeb
    Just to set the record straight and correct myself, , forget dropping in an IT200 motor.
    They are nothing like the Blaster, except maybe the top-end.
    http://cgi.ebay.com/ebaymotors/ws/eB...category=34284
    Jeb,
    I think its the DT 200 motor that is like the Blaster's but liquid cooled.
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
  10. #55
    dt200 installed on a blaster,stock blaster is approx 18 hp while the dt200 is approx 31 hp the dt top end is also powervalved
    1983 Honda 110
    1967 Mustang
  11. #56
    Nov 2004
    Waterloo IL
    2,701
    Now that is just awesome! There is your TRI-Z motor right there!
    Has anyone put a TRI-Z motor in a Blaster? I bet that would be quite the upgrade if you're into Blasters.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
  12. #57
    No one on the blaster site i belong to has a tri z motor in a blaster but we do have a guy thats putting a yz490 into a blaster its gonna be one bad ride when done,we also have a guy putting a blaster motor into a 250r honda chassis.
    1983 Honda 110
    1967 Mustang
  13. #58
    Mar 2004
    North Central Ohio!!
    2,712
    The guy I bought my Tri-Z roller off of has one. That's how I got the roller. He took the engine out and installed it in his Blaster.
  14. #59
    Mar 2004
    2,712
    This project is still on...
    On the back burner till the 500 is done, but I have some fresh ideas today!
    Small bore MX sounds like a better idea than flat track, besides Andrew is going to need some competition!
  15. #60
    Detroit, Michigan
    16
    A destroked motor will be significantly different from stock in power delivery. Deboring is the best way to go, and is what yamaha did for their support riders in the 200 class. If you want to get radical ,another option is to overbore a yz 125 engine. I had one of each of these years ago , when i was under age to run 250s at aatva events. The 125 motor was really good for flat track ( consistent high rpm) while the debored 200 was better all around. There wasnt as much difference in usable power between a modified 200 and a modified 250 as many people would think. Good luck.
