I just finished my CR500 rear shock conversion on the 250R. I installed mine with the stock linkage. The 500 shock is appr. 1" longer than the 250R shock. This raised the rear of my trike about 3". So the pondering question is whether the added height will be an advantage or a disadvantage. I fear that it may hender the turning ability of the bike.
So my seat height is now at 32". That's one inch lower than my Z. The bike now fits me great and I feel alot more comfortable on it. I now have 13" of clearance from my frame to the ground.![]()
I'm going to test it out tommorrow and see how it works. With lots of travel and soft compression it should soak up whoops like their not there, but turning may be it's downfall. Sure looks goofy though!
So what do you think? Compromise suspension and bottom out on big jumps to turn faster, or soak up the jumps and loose some handling capabilities?
Just for the people who don't know me. The reason I did this is because i'm 6'4" and 240lb. No stock trike was made to handle what I want to do with it.
Now I wonder what they were.
