Does anyone know, or has anyone used a rear spring off of a CR500 on the stock shock body. I'm not positive but I believe that the CR500 had a stiffer spring than the 250r both being stock. Just curious as I may have access to a CR500 rear spring.
1985 ATC 250R
1986 ATC 200X
1986 TRX 250R
I'm not sure about whether it will fit or not. Mine is an aftermarket Ohlins shock and the spring is much longer than the stock R spring.
Measured the forks a little closer today. I got 3 1/2" difference in length between the 2. Going with a 21" front tire on a 10" wheel will get me to a dif. of 2 1/2". Still pondering how to get it to be closer to stock. I would guess that the CR forks will sag a little more from the weight of the trike.
Hey Derrick, did you measure from end to end, or from the axle mount hole to the top of the forks? I made that error when I was comparing forks before..
I measured from axle mount to the top of the forks.
