i put the beater plastic on it for a pic!!!
Looks pretty good...any close ups of the frame mods and stuff? From what I understand the exhaust port is to tall to fit under the down tube so you have to notch the frame or something for the motor to sit low enough?
the frame is notched and dimpled to get it low enough. i bought some tubing and plan to redo the lower cradle if i get any cracks.
so you waiting for a chain? and the button ups... is she basically ready to rock?
adam
86 ATC 500R the duner..
1985 ATC 250R Bone stock!!
1985 ATC250R mx/duner
1986 TRX370R MX/Duner
could you explain how you dimbled the frame i am thinking of pulling this off... also how hard was it to do? i know you have to know how to weld and it takes time to fit all in there right.. but could you explain how hard you thought it was? and a picture of the dimbling
adam
no pics of that. just heat the area with a torch, place a metal rod over the area, hit the rod with a heavy . you have a dimple. it is alot of work. i have a whole thread of this on the .org website in the pics section.
