Thread: oil cooler on big red
    Guest
    could i put a 350x oil cooler on my big red it is an 85 250es big red need answer real soon thanks kyle
    Howdy's Avatar
    Celina, Ohio
    10,079
    Yes, you can but it will require some machining / fabrication. The side case would need drilled and tapped in the proper spot.
    Guest
    i heard that an oil cooler would be bad for it. thats what the people from 3wheeler.org say. they say it will lead to problems later on .kyle
    Howdy's Avatar
    Celina, Ohio
    10,079
    If a oil cooler is bad for it then why do 350x's have them?
    Sure you could ask: "Well if they were good for them why didn't Honda put one on it?" My theory is cost and weight.
