Originally Posted by
3Razors
Im calling BS on this one. Wrong on both ends buddy. The vibration in a 3 wheeler is very minimal. It will take much more than your 250r with a 310 kit run down even a stock cr500. And as far as reliability?!! The cr500 motor is one of the most well built motors ever! It is stone ax reliable that can take lots of abuse.
Ok,first,there is no counterbalancer in a cr 500,so there IS vibration,and it DOES cause some problems!Second do you know how much HP a stock 500 makes?Do you know how much a well built 310 motor can produce?If you did,you wouldnt be talking out your *Edited**Edited**Edited**Edited**Edited*!I never said it cant be done,hell Ive had 2 of them!I was only warning about some problems,is that so bad?
85 250r drag bike
87 trx 250r ESR big bore
