Results 1 to 7 of 7
Thread: brake pads
    smyers33 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Tennessee
    416
    brake pads
    I bought new brake pads today. Took out the old ones... and now I can't figure out how to get the new ones to fit. The round thing that presses the pads to the rotor won't go down. I dont know if its supposed to or not. I looked at my manuel but its no help. Please help
    1983 250r
    1986 200x
    1985 250sx
    Pete is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2003
    Lino Lakes, MN
    229
    use a c clamp to press the pistons back into the caliper
    Jul 2006
    Tennessee
    416
    On the way out to try it...
    1983 250r
    1986 200x
    1985 250sx
    Jul 2006
    Tennessee
    416
    Alright C-clamp worked great. Got my pads in but they are loose as a goose... I took the little plate off the outside and hit the pin with a ....No luck and probably not a good idea..How do I get them snug?
    1983 250r
    1986 200x
    1985 250sx
    Pa.'s Highest City
    8,058
    You got to bleed the brakes.
    Jul 2006
    Tennessee
    416
    Earlier when I had no clue what was going on I drained all of the brake fluid out of the cylinder down by the rotors... Also I can't bleed my brakes properly beacause my brake bleed screw is stripped... I tried to bleed where the hose goes in. Still no brakes.
    1983 250r
    1986 200x
    1985 250sx
    You also need to make sure that the 2 slide pins are not seized and allow the caliper to float into position. You'll need to get a good bleeder screw....
