Thread: help me plzzzzzz
    Jul 2006
    western ny
    3,366
    help me plzzzzzz
    guys i need some help again. when i drive my 3 wheeler it runs like crap (slugish) until you pin the gas then it clears up. what could it be? it lets out exhaust that smells like a tractor pull. someone told me its running rich. if its any help it back fires when i give it gas. the air screw is set 2 1/4 turns out. that is what the book says to set it at.
    i am begging you guys i need help. it seems like every time i get it running it takes a crap again.
    GIT IT RAAAGGGGG !!!!
    triker111's Avatar
    triker111 is offline At The Back Of The Pack Arm chair racerFirst time rider
    miami
    162
    you said it was running fine for a while. maybe you keep getting metal bits from the tank in the carb. do you have a filter screen on there.
    savin one atc at a time
    Jul 2006
    western ny
    3,366
    yep i got a filter
    Oct 2005
    Pennsylvania
    863
    Does it backfire from the carb or out the exhaust------
    From the carb is too lean --out the pipe is too rich----
    Sounds like the float is set too high,
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Jul 2006
    western ny
    3,366
    it is coming from the pipe. i will check the float.
