I don't know if anyone remembers or not, but for a while now I have been working on the completion of my 1986 250R conversion to the Sabertooth 500cc engine package in my spare time from running the shop around here. Well it's done...sort of and here's what I've learned...
The Sabertooth 500cc engine conversion package is a real MONSTER and the build quality and workmanship from those folks is superb...couldn't ask for better. The power this thing makes is just silly and to be quite honest...far too much torque for this machine in the trim it's in, even with a +1" longer swingarm. I just can't keep the nose down, so riding it at full throttle is a huge lesson learned in throttle modulation to the point where I just can't pin the gas anymore where the tires will hook like I used to with the stock engine, otherwise~ I'm on my back.. I guess a high HP engine like this might be better suited for a full-tilt drag machine, rather than on a standard (and even mildy modified) ATC.
Now for the bad part.... I can't keep the transmission alive in this thing!!! Burning clutches, broken trans. gear teeth...everything and it's getting old. I'm a 230 lb. 5'-10" guy, so maybe that has something to do with it and a lighter guy might have better luck...but not me. The damn thing's transmission is broken again and this time, I think it hurt the case internally when it broke. I'm done with it for a while and I think I'm going to pull that engine and shelf it until I get the motivation to take the thing apart all-over again...![]()
I can't begin to tell you the insane amount of money I've got in this engine with all its trick parts and that's why it makes me ill to see her down again. The engine wants to run hard, but the trans won't take it for very long...![]()
Anyone have any ideas on who produces HD transmission parts for the 250R? What about ESR's engine stuff? If I have to build another engine, I'm going to do it a bit tamer this time so the trans. will hold together for more than a couple of weeks at a time...
Thanks for the vent time...carry on!![]()
john p
