Results 16 to 30 of 37
Thread: Place your bets....or a Magic Trick!
    theonlyjosh's Avatar
    theonlyjosh is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2006
    Ontario, Canada
    276
    well, looks pretty brutal, soak it in something for a long long time and than go crazy... goood luck!
    I am a diehard Ford/Honda guy.
    Previous Trikes:
    1983 Honda Atc 110 (Stolen)
    1985 Yamaha 200N Tri-Moto (Sold to dad)
    Dream Trikes:
    1985-1986 Honda 350x
    Current Vehicle:
    1993 Ford Ranger XL Regular Cab, 4x4, 3.0 V6, 5 Speed.
    Dream Cars:
    1990 Ford Mustang GT 5.0 (Manual)
    2008 Ford Ranger Ext. Cab 4.0 5 Speed (Fully Loaded)
    florida
    2,328
    syko do u have any other engines that are like that i could screw around with in auto shop? lol or any trike stuff for that matter
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Ahh hell a little bit of black paint and a grid painted on a piece of plywood in the background and you'll be ready to sell that mofo on ebay for top dollar under the username "jerrylance"
    Jul 2006
    not at this time red rider
    florida
    2,328
    ok thanx im still waiting to get a job im bying parts for john dale and some nos stuff from honda lol but i cant fin a job and my trans. just died ( 1988 Kawasaki ke100 lol) pix:
    the flywheel magnets broke when i went to fix the ignition the points were bad and a flywheel is 360 bux from kawi
    (and yes thats my parts machine in back just no motor lol and yes my turn signals ARE dangling by the wires lol i have new ones from ebay on the way tho cuz i got a ticket)
    Mar 2005
    overton, PA
    5,257
    hey man throw it back in th elake its too small lolyou want its bigger air cooled daddy lol
    Maryland
    3,077
    Quote Originally Posted by sykolincoln
    holy crap!! I didnt really relize how bad that thing looked, I told you it was nasty, oh and it WAS A M'Fer!!! trying to get the old frozen bolts out of the engine to get that thing out of the frame! Im sorry pleazz dont be mad at me we cool?
    Ha dude, I don't care man. I asked for it! Thanks for all your effort, hopefully I can salvage something.
    I be the crank halfs could be blasted and poished good as new.
    The electronics seem ok, flywheel is good.. I'm really interested in the left hand engine case. Its better than the one thats on my Z right now. I see 2 chips missing and that crack you were talking about. I also see a chip that looks suspect on the bottom end but I don't think its anything that can't be welded.
    Its gonna be a challange. I got the flywheel and stator out, and its been soaked down with PB blaster several times now. Updated pics tomarrow!
    Jun 2004
    potsdam ny
    1,227
    it looks solid, lol...but seriously i agree with the bead blasting and soaking....i bet if you soak it for a week in oil and then bead blast it after you get it apart you should be ok, i bet the tranny isnt to bad, remember if you break a bolt off, it isnt the end of the world, if you take your time you can drill them out perfectly, use the right size bit with a helicoil kit and the threads are stronger than stock... just remember to use new bearing and seals, lol....
    Aug 2006
    Madison, TN
    46
    That looks like some of the stuff I bring home.
    It's not so funny MEOW, is it?
    Maryland
    3,077
    Alright well a little more progress. Got the flywheel and stator out. Not too much drama other than I wrecked my flywheel puller. Looks like I have a decent usable electrical system. yay.
    Well my liabilities seem to be one chip and some damage to the clutch lever actuator housing. Shouldn't be too terrible to weld. I just gota get some practive on aluminum first.
    I kinda almost thought this was a lost cause for a second. I was cleaning the bottom of this thing with a wire brush when I unearthed a blobl of jb weled slather accross both halfs of the case. Luckily the blob was covering a small hole on the right half and the bottom of the left half is in good shape.
    Tomarrow I'm gonna try spliting the cases and then the real fun begins, getting the bearings out without destroying anything. And tips on getting the dumb needle bearings out?
    heat and a slide !!! blind bearing puller..
    illinois
    743
    it was worth it sand blast it call or take it to a blasting company they can do it
    ?? mags worth? crank?? you need something to rebuild you know
    tranny can be blasted you dont need the berrings lol
    a dremal would work for some stuff
    screws are in alluminum dont need soaked!!
    crank can be pressed apart and blasted -or wire wheeled
    blah blah blah
    Maryland
    3,077
    Well an update, or maybe TADA!!!
    Here's my cases. All blasted, welded and almost ready to go.
    The welding isn't unoticable but I'm very happy espeacially since they were welded for FREE! Did a little grinding to smooth out the welds.
    The clutch actuator area is repaired wonderfully couldn't be happier.
    Another shot. I'm not sure whether to just run these naked, or paint/powder coat them. Can't decide.
    Final shot.
    Well I think my $30 dollar engine cases turned out pretty well. The only thing I need to do yet is thoroughly lap them. The gasket sufaces are rough and I'm sure that a good lapping would make the engine fit together better. So thats next on the todo list. I'm thinking I'm just gonna build a whole engine then swap it into my Z and redo the other engein cases as well. This one's gonna be done with the YZ ignition and setup for MX. If they get coated, I'm thinking bright yellow.
    So can anyone tell me what my best options for all the bearings might be? Every last one is getting replaced. Does DADS do all bearings or just certain ones? Gonna hafta PM him.
    I also ended up with a good Z crank, trans minus an output shaft, and some other tri-z odds and ends. Overall a good haul for 30 bones.
    Aug 2005
    slc ut
    51
    I think you should put it back in the toilet and try flushing again. Don't touch that, you don't know where it's been.
    '84 atc70
    '85 tecate
    banshee (too many wheels)
    '04 Suzuki LTZ400
    Yamaha G9 Golf cart
    Riding on three, sets you free!
  15. #30
    Maryland
    3,077
    Quote Originally Posted by p_hefe
    A rather odd responce.
