Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Thread: Starting the CR60 / zinger project.
    Jackson MI
    1,688
    Well I bought a cr60 engine, frame, swinger, fork's, tripples. I have an extra Zinger frame, tank, plastic. I will start combining the 2 frame's tomorrow. I will use the front pivot section of the cr swinger. I will use a 86 200x rear swingarm section, axle carrier, & axle. I hope all goes well, but there Is alway's something that won't go according to plan. I will post up pic's as I make progress.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    nice cant wait to see this yamahonda!!!!! gonna call it a ZR60?
    Jackson MI
    1,688
    Good Idea Bryan that sound's right does'nt It..
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Apr 2003
    Spanaway, WA
    1,240
    Isn't an X axle going to be kinda wide? Sounds like it'll be a BA little rig when it's done.
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    i bet a blaster axel would be perfict for that little monster!
    smyers33 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Tennessee
    416
    Keep us updated on this one. I'm very interested to see the outcome. I want to do a similar project with a cr80 engine.
    1983 250r
    1986 200x
    1985 250sx
    Jackson MI
    1,688
    I think the 200x axle will be perfect. It's narrower than a 250r axle & quite a bit smaller In diameter & lighter. I might have to add some weight to the front end to make It fly flat, but what ever It take's.
    Raffa, I really want disc rear brakes & the Honda style chain adjustment.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    3leggeddog's Avatar
    Nov 2004
    ahhhh,the mad scientist back at work.it's too bad we live 3 hours away from each other or we would building some crazy chit nonstop.or maybe it's a good thing,lol.already get in trouble for being in the garage for 8-10 hours at a time.
    good luck jason,i am sure it'll turn out great!
    Jul 2006
    Tennessee
    416
    Are you using the cr 60 forks or other ones?
    1983 250r
    1986 200x
    1985 250sx
    Billy Golightly's Avatar
    Live Oak, FL
    15,067
    The 200x actually doesnt have the concentric chain adjuster like most Hondas. But what you can do is run a 200x axle in an 83-84 250R carrier (which is what I did on my 500R) then you've got the small narrow axle and a real chain adjustment system and not that sliding swingarm deal the 200x uses.
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by Billy Golightly
    The '86 200x does use the concentric adjuster.
    Jason, Are you just going to cut and widen the CR triples?
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Jackson MI
    1,688
    Billy, I will be useing a 86 200x rear swingarm section on the cr60. On another thread I'm trying to find out about a bigger sprocket for the 500 with a 85 200x axle In It.
    Thefox, Yes I was gunna widen the stock CR tripples, but I ran Into a slight problem. With the zinger tank & top frame section on the Cr frame the steering stem will be to low. I don't think the stock cr fork's will give me enough ground clearance (to short). So I might modifi some 200x tripples & use the longer fork's not quite sure yet. I need to sit everything on & make sure It all clear's. I will have to bend the pipe down a little to clear the zinger tank. So far It has'nt been real bad. I will post up more pic's later.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Jackson MI
    1,688
    Here are a few pic's of my progress. Got the top section put on so the tank fit's, also had to shorten the pipe about 1/2" so It will clear the tank. Welded the subframe on, so the plastic will fit. I will work on the swinger soon. so I can figure out my ride height. Then I can set the rake & figure out what I'll do for the tripple's. I just sat the cr fork's on to see how they would look. It wont sit that high so they look kinda goofy.
    Attached Thumbnails Attached Thumbnails zing topsec.JPG   zinger w  subframe.jpg   forks & plastic.JPG
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Aug 2005
    Winnipeg
    72
    You sure dont waste any time! Cant wait to see it done
    Sep 2005
    FL
    855
    Quote Originally Posted by ghostridermb
    I thought the same thing. Looking good.
