Hey all you Ute riders.....Got a Big Red, an SX, 225DX, or any other workhorse with electirc Start and reverse?? Ever feel left out at some of the TrikeFest Events? Well, here is you chance.
The first day I am at TrikeFest this year, I am heading out on Haspin Acres to set up a pretty short, very technical closed loop track. Creek Crossings, Log Hopping, Mud crossing, Technical off-camber trail layout, and the like.
The main objective is this - You'll start by standing by the time starter (your trike will be sitting near you, not running). When started, you'll run to your machine, start it up, run the short track 3 times, and at the end be required to back into a tight spot and park the machine (thus needing reverse). All of this will be timed. You'll be penalized 5 seconds anytime you put your foot down, get off your machine, or leave the marked track.
This will be a timed event. You will not be running against anyone else on the track at the same time. Best time wins. NOTE: this will be a very technical coarse - Mud and log hopping skills will help you alot. This will similar to a "trials contest".
This may be accompanied by other Ute Events, such as a pulling contest. We are in search of a small garden tractor pulling sled right now. If you know of anyone that has one that will let us use it, please let myself or FarmerC know. Other events may also be in the works. Hopefully, if there is enough interest, we may get our own timeslot at TF for this event. Post up your thoughts.
Also - we'll need a couple of spotters on the track to watch for penalizations, and to help aid in record keeping.
Inputs welcomed at this time!
