Hey all you three wheeler world nuts!!!! If you have a Honda 350x, or 200x, I have a secret for you. I decided to reveil this because I know how you feel if you have a stuck rear brake master cylinder.
First step is to get that cylinder unstuck well you need a drill, drill bit, vise, screw driver, small screw with coarse threads, and a slide.
Second take out the snap ring with a pick or snap ring pliers.
Third drill a hole straight down the center of the piston. Warning this must be straight!!!!! make sure the drill bit is not to big for the screw you are going to use to put in the piston after the hole is drilled.
Fourth install the screw in until the head is slightly above the piston bore you can now use two screwdrivers and pry on each side to get the piston out slowly but surely just be patient and try really hard not to damage to bore.
Fifth take a wire clothes hanger and a scotch brite pad, cut about a six inch piece off and fold it in half, rip off a small piece of the pad and stick it between the hanger you just folded and chuck it up in your drill, try to get it centered.
Sixth lube the piston bore with lots of WD 40 install the contraption you just made with the hanger and pad. use this to clean up, hone the bore, use a slight in and out motion.
Now for the biggest secret a kit for this I searched long and hard and found this buy a kit for one of the following found mine on ebay. for about 35.00 much cheaper than trying to buy one that works this forum will expire soon!!
CB1100F Supersport (83)
VF1100C V65 Magna (83-86)
CBX (81-82)
CB1000C Custom (83)
CB900C Custom (81-82)
CB900F Supersport (81-82)
CB750F Supersport (81-82)
CX650T Turbo (83)
CX500TC Turbo (82)
FT500 Ascot (82-83)
Please keep this secret to us 3wheeler freaks![]()
.....I didn't realize to look at the date that Timmy posted the thread. Anyway, I am out 35 dollars and I can't find a rebuild kit!,,,,
Team Red Trike
1985 and 1986 use the same rear master cylinder!! I am going to a friends house and check his 04 Honda 400ex. Maybe the 400ex's rear master brake cylinder is somehow combatible with our 350x's. My search begins!!!!
